Exception "Invalid part tag"
Hi all,
I wanted to write some function which starts with opening of part then it do somethink and finish with SaveAs. But during SaveAs method I recieve for some parts exception with meassage "Invalid part tag", errorcode is 641018. I don't have any idea what does it mean surprise
Code:
foreach (string path in partlist)
try
session.ListingWindow.WriteLine(System.DateTime.UtcNow.ToShortTimeString() + @": " + partlist.IndexOf(path) + @" : " + System.IO.Path.GetFileName(path));
dp = session.Parts.Open(path, out pls);
dp.SaveAs(conf.TargetPath + @"\" + System.IO.Path.GetFileName(path));
catch (Exception e)
session.ListingWindow.WriteLine(e.Message);
finally
if (dp != null)
dp.Close(BasePart.CloseWholeTree.True, BasePart.CloseModified.CloseModified, null);
RE: Exception "Invalid part tag"
Make sure when you open the part, the part has opened successfully. Also, you can check before saveas that the tag is not null.
Suresh
www.technisites.com.au
Dear Suresh, I checked it. If I try to open part by hand and make SaveAs it works fine. I checked with debugger if I have Tag for part and for session. I think that problem could be somewhere else. I want to use this function to break family members. But I didn't find any different way how to do it, only this SaveAs operation. What is strange that it appears only with few parts.
Well, I solved it myself:
CODE --> c#
                try
                catch (Exception e)
                    dp = session.Parts.OpenDisplay(path, out pls);
                finally
                    if (dp != null)
In the case exception appears I close part and open it again and display. Then I call SaveAs and it works.
