Best practice for framing?
Hi, just a question for thoes of you who are proficient with framing. We've designed a piling template, which consists of a quarter circle structure built mainly out of square tubes, three stories high. It's become some kind of monster full of errors and parts disappearing so I've redone the entire assembly. In the new version I've kept the framing seperate, so I've inserted the frame.asm into a higher assembly and then added all other steel plates etc. This seemed to work better and also this assembly was much smaller (in bytes) than the monster assembly full of errors.
Can anyone say if this is common? Do you keep your framing seperate and insert these into a higher assembly before adding all other welding parts?
Griffin
Griffin
RE: Best practice for framing?
Tony
Framing is nice, unless you've got curved members, in which case it's a royal waste of my time and effort!!
It is possible if you are on ST5.
Follow instruction in attached image.
Tony
Unfortunately we're still on ST4. This post has managed to make me more convincing to upgrade to ST5, so this is something we'll be doing very soon.
