Surface finish measurement
Hi
This is PVK Raju I would like to know how to measure surface finish on inside groove machined part
Example: We have one of the machined part (component) like inside groove width 3mm only (as per drg. surface finish is 0.8Ra)for that we have to measure surface finish and Surface finish tester probe unable to move ,because width is is very small. And also standard reference blocks unable feeling by hand due to width is very small.
For the above situation how to measure the surface finish
Anybody have ideas please suggest me and help me
Thanks & Regards,
P V K Raju
Thanks & Regards,
P V K Raju
RE: Surface finish measurement
David
Alternately, you could have the shop make a sample with a wider groove using the same process. Wide enough to use your contact profilometer. That would give some degree of confidence in the process.
http://www.bruker.com/products/surface-analysis/3d...
http://www.brownandsharpe.com/products/optical-mea...
http://metrology.zeiss.com/industrial-metrology/en...
.8 Mu millimeter (32 Mu in) is this correct.
is a very simple to machine & very simple to measure with profilometer.
contact the sale engineer rep of your particular instrument & ask for the correct TIP.
http://www.swissinstruments.com/downloads/metrolog...
or check this one with the optional probe tips.
HTH
Mfgenggear
if it can be built it can be calculated.
if it can be calculated it can be built.
Every one thanks for your immediate response
Yes,it is Inside groove and it is O ring groove only. But as per customer requirement we have done machining operation but we are unable to measure the surface finish
Thanks for your valuable advise. Other then profile meter is their any easy solution?.
We have this type parts are very small lot qty. We are unable to buy this type instrument (cost fact)
Is their any suggestion please me.
Thanks and Regards,
P V Krishnam Raju
Pay to have an outside company verify it.
HTH
Mfgenggear
