soleniod valve for pnumatic actuator
Can someone please recommend a soleniod valve for use for a pnumatic actuator. The actuator will be open/close duty and we need a weather proof stainless steel (not brass) 24VDC soleniod valve to control the actuator.
Hoefylly the valve can be easy to mount on the actuator aunf plump up.
The actuator is small (for DN80mm valve)
thanks
Kevin
thanks
Kevin
RE: soleniod valve for pnumatic actuator
2. What is the actuator maximum operating pressure?
3. What is the type of gas?
4. Do you mean the valve will be operated by PWM (Pulse with modulation) by controlling the duty cycle of the valve open/close times?
5. What is the maximum allowed open time (T_on) and close time (T_off) of the valve?
6. What is the frequency of the open/close of the valve
7. What is the supply current your system can provide?
8. Maximum and minimum environment temperatures?
