Mirroring a model
Mirroring a model
Is it possible to mirror a model that you have already created....for instance:
I have a model of an interior that is FWD facing on the RHS but I need it to be the exact same model FWD facing on the LHS.
My experimenting has not yielded very good results thus far...ideas, thoughts?
RE: Mirroring a model
• If you want to GENERATE new elements based on existing ones, for instance by symmetry of the existing mesh, then use "Mesh > Reflect > Element".
• But if you wand to MODIFY an existing mesh, then you can use commands from the MODIFY menu, bases in your explanatio probably the best that fits your needs could be "MODIFY > ROTATE BY > ELEMENT". If your FE model is "geometry-based", is better you rotate the geometry and then re-mesh. Or Rotate both geometry & mesh and you are done, not any additional action needded!!.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
When the future's architectured
By a carnival of idiots on show
You'd better lie low
