khrone magnetic flow ( error )
Hi all,
I face a problem in KHRONE manetic flow transmitter, ( application error ).
But i don't know what is the actual reason for that.because it appears to me suddenly ( i am in commissioning so this pipe line is empty ) , has it relation with my status?
Because when this line has flow this message would be gone?
Thanks in advance,
Maher
RE: khrone magnetic flow ( error )
Typical electromagnetic flowmeters do not work when the line is not fully flooded or has entrained gas. Most likely this is where your error is coming from. You should read the manual.
Magnetic flow meters typically require a pipe full of flowing liquid. This is probably where your problem lies. Magflow meters are also restricted to liquids where conductivity is at sufficient levels to induce measurable voltage but hopefully thisis not an issue
