Inherit feature parameters
A small suggestion...maybe useful, I'm not sure if something like this already exist (I haven't seen it), but I would like to see "inherit feature parameters" option. For example when you place a feature (e.g. hole) or user defined feature and later you need to create similar or exactly the same, you could copy parameters from original feature (not positioning dimensions) by clicking on inherit button and then on feature directly on model or in part navigator. That way you wouldn't need to type parameters again and again.
Thanks.
Thanks.
RE: Inherit feature parameters
NX3 + TC9
