how to display a load -displacement curve in abaqus
I build a simple tension model in abaqus using displacement load, how can I choose output parametre to
get the load across the section.
RE: how to display a load -displacement curve in abaqus
To confirm that, you may apply the result in a new model data base using a pressure or concentrated load instead of displacement and check the stress distribution on the model which should be the same as before.
http://www.youtube.com/watch?v=vA1UUmea06E
Firehole Composites
www.firehole.com
