U-tube heat exchanger enquiry
Hi all,
I have a problem with designing a heat exchanging system. Currently, I am planning to use a U-tube HEX (2 passes) to heat up the feed by using steam. What's my major concern is overheating my feed as I am using steam (1.5bar) as my heating source. It is not a turbulence flow yet rather it is in the transition state. I would like to ask if it is possible to overheat my feed at the moment where the steam begin the heat exchange with the feed?
RE: U-tube heat exchanger enquiry
StrykerTECH Engineering Staff
http://www.stryker-tech.com/
So if your steam is hotter than you want your feed you should temper the steam first.
Plymouth Tube
