Parameter from relation
Hi.
How to create relation to add á components dimension to one paramter like below.
Parameter_SIZE: Length(D1) x Width(d2) x Height(d3)
Example in paramter field:
30x20x5
RE: Parameter from relation
You will need a complex relation that usues the istr function, Integer to String.
You will need to convert each parameter to a string, then build your final string to put it back together.
Ben Loosli
Hi and thanks.
In relation i thought this shuóuld work esealy. "x" is text only
Parameter_SIZE=d1 x d2 x d3
I now how to do it width more parameters but i did think is could be done with only one paramter.
Can ju give me an example with istr function?
I had the function wrong, it is ITOS.
Parameter Length = 5.5 this code will set Title_2_2 to 'X 5.5 LONG'
Parameter Length = 3.0 this code will set Title_2_2 to 'X 3 LONG'
IF LENGTH - FLOOR(LENGTH) == 0
TITLE_2_LEN = "0"
ELSE
TITLE_2_LEN = ITOS((LENGTH - FLOOR(LENGTH))*10)
ENDIF
TITLE_2_2 = " X " + ITOS(FLOOR(LENGTH)) + "." + TITLE_2_LEN + " LONG "
Ben Loosli
