Hi, I have a simple model under a l
Hi, I have a simple model under a load. I want to find the load in which the von mises stress in one point in my model reaches a critical value. My model is a single pipe and the loading is internal gas pressure. I didn't find any tools in ABAQUS to define this criterion. How can I find this load? Should I employ a specific type of step or defining a damage? I have tried these methods but still I had no success.
RE: Hi, I have a simple model under a l
Put a load larger than the one u expect, let abq write out a lot of timepoints, and just read it from the output (at time < 1).
If the material is not yet at yield, repeat with a higher load.
Pro:
use *EXTREME VALUE with HALT=YES
I don't know if there's something similar for standard.
