Light blocking material
What is the best light blocking plastic material which can block as much light as possible. The material can be as thin as 0.020" (or machined to this size). We used black plexiglass before but when it go down to this thickness, light start leak through.
RE: Light blocking material
Hello Patprimmer, any example you can share with for plastic with carbon black?
Thanks.
