Negative pressure for contamination containment
Is there a maximum acceptable differential pressure between spaces before special precautions need to be taken for personnel?
With pressure fluctuations between spaces for transient conditions like door openings the rooms can fluctuate between -0.02 to -2.75 inches of water.
Having been exposed to air locks at BWR nuclear plants I remember 12 psi absolute in the building and being able to enter it with no special depressurization adjustment time, is this still acceptable? Personally I am not worried about a delta p of 2.75 inches of water but I don't want to overstep an OSHA restriction.
RE: Negative pressure for contamination containment
