Meaninig of "positive" or "negative" value of End of Life V
What's the meaninig of "positive" or "negative" value of a End of Life Vehicle?
Maybe that the value of the scrap obtained from an ELV could be higher or lower than its dismantling and recycling costs?
RE: Meaninig of "positive" or "negative" value of End of Life V
Correct.  An item that has a positive end of life value, can be sold for that value at the end of its life.  An item with a negative end of life value will cost you that value to dispose of it.
Clifford H Laubstein
FL Certified PE #58662
