NX 8.0.3.4 - hole table / weird values
Hi all,
i am quite new to the community.
I have a big problem with my hole table in NX 8.0.3.4.
When i create a hole table, as the help function would tell me, i end up with weird values for my x and y dimensions (see attachement).
Drawingw as done in milimeters. There is no multiplier which fits between the x value and the x real distance, same for y value and y real distance.
BTW: I am not able to pick single holes or use the function "Window Selection". Any idea why?
I am kind a lost and i would need to finish some drawings until Monday :)
Maybe you could help me out.
vallafe
PS: if attachements not work links here:
http://files.engineering.com/getfile.aspx?folder=5...
http://files.engineering.com/getfile.aspx?folder=4...
vallafe
