HELP WITH HOW TO CALCULATE THE THEORITICAL VALUES FOR PLOTTING THE PRESURE VOLUME PLOT FOR HYDROTEST
Gents,
Am preparing for a hydrotesting job.
I need a formular to determine values for pressure and volume i.e for plotting theoritical DV/DP, which will then be used to compare with the field values to determine volume of entrained air in the pipeline during the hydrotest.
Having a bit of a challenge in the application this formular
DV/DP = V*[ (D/(E*t)(1-V2) +C]
Where V = Volume (gallons)
D = OD inches
t= wall thickness inches
V poisson ratio of steel pipe = 0.3
C =Compressibility of test media (inch3/inch3/psi)
Dont know what THE VALUE OF COMPRESSIBILITY OF WATER in Inch3/inch3/psi
Will appreciate any advise or alternative way around this .
many thanks
RE: HELP WITH HOW TO CALCULATE THE THEORITICAL VALUES FOR PLOTTING THE PRESURE VOLUME PLOT FOR HYDROTEST
I suppose that the V in front of the formula is volume, not Poisson. Also the Poisson's ratio does not have its place in this formula, but its influence is, as always, quite small.
See FAQ378-1339: Pressure increase due to thermal expansion of a trapped liquid , where you can take αfΔTV/V and αvΔT=0. There you'll find also the compressibility of water.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
You are missing one closing parenthesis in your formula.
Hello Prex (Structural) and Chicopee, I thank you all for responding.
There are two V s in this formular. First one is Volume (big V) second one is supposed to be small v squared for poisson ratio. i wrote that as V2.
Also there is a clossing parenthesis missing. The correct representation is as shown below. Sorry for the mix up.
DV/DP = V * [ (D/(E*t)(1 - v squared)) +C]
D = OD inches
t= wall thickness in inches
v= poisson ratio of steel pipe = 0.3
C =Compressibility of test media (inch3/inch3/psi) (inch3 = cubic inch)
