NX8.5 Easy Fill
NX8.5 Easy Fill
I'm trying to use the new Mold part validation tool but doesn't work.
Go to Analysis-> Molded part validation-> Easy fill and then Run Flow Analysis but an error came out : "No Flow Analysis application is found"
http://www.youtube.com/watch?v=SS6Atf3XFK4&fea...
Thank you...
Using NX 8 and TC9.1
RE: NX8.5 Easy Fill
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: NX8.5 Easy Fill
In that zip file should be the moldex3d folder which needs to be copied to ...\Siemens\NX8.5\Moldwizard\
I have tested and as long as you have a Moldwizard license, it should work.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.6, NX6.0.5, NX7.0.1, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.2, NX8.5p21
RE: NX8.5 Easy Fill
thank you for your suggestion, but doesn't work, maybe some packages installed in my machine are in conflict to the package that Moldex need.
I will report to GTAC.
Thank you...
