Viscosity independent Frequency
I run a Dynamic Frequency Sweep and I found that the Viscosity is constant at all times. I mean independent of the Frequency. What does that means? Both G' and G" are dependent of the frequency.
I also run a Steady strain, ad I found same results, Viscosity independent of the rate. What does this means?
Thanks for the help
Thanks for the help
RE: Viscosity independent Frequency
