Inspection note-custom symbol
Hi I'm trying to create a custom symbol that will have partial editable text. See the attached image. The symbol will be added to critical dimensions and the numbering will increase with each symbol insertion. The note on the left is placed next to the title block and the number increases to the the number of inspection points added to the assembly/part drawing. Only way I found so far is by smashing the symbol or I found a older posting that tied it to an attribute but each symbol needs its own number. I'm running NX 6.0.5.3.
NX 6.0.5.3 in Windows 7
Mechanical designer
RE: Inspection note-custom symbol
www.nxjournaling.com
Mechanical designer
