All, I am working in AcadR14 (windo
All, I am working in AcadR14 (windows) and am having the following trouble.
I have set the precision for linear dimensions and angular measure to the highest possible and have also set the dimension annotation for the same. I have entered the angles, linear measure etc accordingly but when measuring the angular dimension acad only shows the angle to the nearest degree. The linear dimension is fine and is reported to the desired level of precision. What happened to the angular dimension? What do I need to do to correct this? For example, I enter the degree as 79.085193 and all acad reports is 79. I have checked the annotation and it is consistent with the linear measure precision.
I suppose I could start a new drawing with the appropriate setting and import my drawing as a block etc. But I would rather know how to correct this problem within the drawing I am currently working in.
Thanks for your help.
RE: All, I am working in AcadR14 (windo
Have I done something wrong? Checking in the wrong place? Nothing seems to work!
If you find a solution, be sure to post it here.
Good luck.
