Annotation with symbol "<" or ">"
I know that <o> is used to have the diameter symbol.
How is it possible to have the symbol "<" or ">" with NX7.5 ?
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: Annotation with symbol "<" or ">"
hope this helps
Best regards
Simon NX7.5.4.4 MP8 - TC 8 www.jcb.com
and then if you have a problem with the "greater than or equal to" symbol just do a search, it's been brought up in here before
I found that:
minor than or equal is given by ALT+8804
and
greater than or equal is biven by ALT+8805
with
font latin_extended or chinesef_kt
Didier Psaltopoulos
Didier,
You found that "minor than or equal is given by ALT+8804 and greater than or equal is biven by ALT+8805, with font latin_extended or chinesef_kt".
I couldn't get it!
Can you send me a "step-by-step (with as many detailes as possible) direction in this matter?
Thanks!
Didier,
Vous a constaté que "mineur ou égale est donnée par ALT 8804 et supérieur ou égal biven est par ALT 8805, avec la police ou latin_extended chinesef_kt".
Je ne pouvais pas l'obtenir!
Pouvez-vous m'envoyer une "étape par étape (avec comme detailes que possible) la direction dans cette affaire?
Merci beaucoup!
Here's an overview of the Latin_extended, special characters etc.
Btw, the "ALT+xxxx" means that you , on a keyboard with a numerical keypad*, press the "alt" and then at the same time type "8805" on the numerical keypad. ( Keep the "Alt" pressed until finished)
* It might/might not work on laptops without the numerical keypad.
Tomas
Thanks, Toost!
