EPANET Question
EPANET Question
I am trying to combine twi epanet water models into one model. Can someone help me out with this? Thanks.
RE: EPANET Question
You can edit the .inp and .net files, if the node and pipe names are not duplicated then pasting one input into the other should work
then you would build the inter-ties. As for the .net files again you would have to verify they do not overlap in the map
Hydrae
RE: EPANET Question
I don't know all of the functions of the software, but I've used EPACAD to pull AutoCAD files into EPANET. It's limited, but very handy. I don't know if it has any functionality with actual EPANET files since I've never combined two before. Might be worth a look, but I think it's mainly for pulling AutoCAD into EPANET.
