Hoop Stress in Bending of Thin-Walled Tube?
Greetings, can someone either direct me to a previous post (I've searched, but not found answers) or help simply answer the following?:
1) Do thin-walled tubes experience hoop stresses when subjected to bending? (tube is open at both ends - no pressure)
2) Are hoop stresses only present in sealed/closed structures subjected to internal or external pressure?
3) If hoop stresses are created during bending, how do I calculate these?
Thank you!
RE: Hoop Stress in Bending of Thin-Walled Tube?
tubes develop hoop stresses in reaction to pressure loads.
tubes in bending develop flugge (i think) stresses as the tube changes shape.
Thank you. As I research this more and more, I think really trying to understand the circumferential stresses that occur in the thin walls of a tube during bending when the tube has ovalized, then when the tube has buckled. Any help would be appreciated.
Thanks!
google "flugge stress", get to NACA 2612. he starts with pressurised cyclinders and goes on to cyclinders in bending (by way of more math than i've seen in a while)
Wow, that was quite the find...thanks very much for your time.
