Move/Copy Object how to change the result by a journal??
Hello Eng-Tips
I have a question regarding how can be possible to manipulate the characteristics (if note change font or size, if line change width) of the instances/copies after using Move Object (Ctrl+T by default) thru a journal, is possible??
RE: Move/Copy Object how to change the result by a journal??
By way of example, let's say you want to copy a note then change the font size of the new note (the copy). Start up the journal recorder, copy the note, change the copy's font, then stop recording. Open the newly created journal file to see what it did.
www.nxjournaling.com
