Transient thermal simulation - Export data from a path
I did a transient thermal simulation in ANSYS workbench (V 13.0) and now want to export the temperature profile along a path for all time steps of the simulation. As I do the usual export command I get only the profile for the last time step. Is there any easy solution? Do I have to use a APDL command snippet?
Thank you for your help in advance.
Best
Zappi
