mixing PP/carbon
mixing PP/carbon
I need to mixing PP with carbon, but composition of PP < 10 %wt. will be prepared with different percentages PP–carbon 6:94 and 8:92. whether it can be formed into a rectangular plate? Please tell me, how about the procedure?
do I need a solvent for PP? does anybody know a good solvent for PP?
thanks
thanks
RE: mixing PP/carbon
What do you mean by carbon. It comes in many forms, however I doubt that polypropylene can we it out at that quantity if mixed with molten polypropylene.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
thanks for your answer
I will mixing polypropylene + carbon black powder, but composition of PP < 10 %wt. will be prepared with different percentages PP–carbon black powder 6:94 and 8:92. whether it can be formed into a rectangular plate?
Please tell me, how about the procedure and method?
I think for carbon black it is probably difficult to get more than 40% into PP. Maybe less.
The method is usually feeding both materials into a twin screw extruderthat melts the PP and mixes the carbon powder into the melted PP
Pat
for site rules
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
Pat
for site rules
Your example is perfect.
Pat
for site rules
Thanks! A compliment indeed coming from you. My mind works in simple terms like that. Easier to relate to than equations and obscure theories.
Chris
Sounds like my wife's pastry!
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
It sounds like rumors of you impending divorce where not exaggerated.
Pat
for site rules
http://www.intertek.com/polymers/testing/ht-gpc/
In some work I did we avoided chlorinated solvents and used a MARSX Microwave oven accelerated reaction system for extraction from CEM where the solvent was 25 ml of a 30% n-Hexane, 70% Ethyl-acetate.
I am not 100% sure that dissolved the PP, it did definitely swell it.
Marko Spasenovic
www.graphenetracker.com
I will try your suggestion
and I still receive more suggestions
