extrusion and cutout relationship problems
I have an extruded cylinder, which at the end, has an extruded loft, which at the end of that, has another extruded cylinder. There is a cut out loft that goes throughout cross-sections of this entire body.
Unfortunately, I'm having problems with defining relations properly. I would like to be able to alter the length of any of the extruded parts, while having all of them still connected and with the cutouts still intact accordingly.
However, when I adjust the length of (for example) the cylinder, I get a bunch of errors.
When I delete the loft extrusion, it seems to work fine though. But then the two cylinders are no longer connected by the loft.
Any help would be appreciated. Thank you.
RE: extrusion and cutout relationship problems
adjust what you want with dimensions on the solid (you might have to lock some like the diameters dimensions).
