Create Notes, a simple way?
Is there is a simply way to create 10, 15, 30...notes using this code lines: (the main concern is to avoid repeating 30 times the same block of lines but with diferent counter (14))
Dim nullAnnotations_SimpleDraftingAid14 As Annotations.SimpleDraftingAid = Nothing
Dim draftingNoteBuilder14 As Annotations.DraftingNoteBuilder
draftingNoteBuilder14 = workPart.Annotations.CreateDraftingNoteBuilder(nullAnnotations_SimpleDraftingAid14)
draftingNoteBuilder14.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane
draftingNoteBuilder14.Origin.SetInferRelativeToGeometry(False)
draftingNoteBuilder14.Origin.SetInferRelativeToGeometry(True)
draftingNoteBuilder14.Origin.Anchor = Annotations.OriginBuilder.AlignmentPosition.BottomLeft
Dim text14(0) As String
text14(0) = "Fecha1"
draftingNoteBuilder14.Text.TextBlock.SetText(text14)
draftingNoteBuilder14.Style.LetteringStyle.GeneralTextSize = 1.3129
draftingNoteBuilder14.Style.LetteringStyle.GeneralTextCharSpaceFactor = 0.8945
draftingNoteBuilder14.Style.LetteringStyle.GeneralTextAspectRatio = 0.8945
draftingNoteBuilder14.Style.LetteringStyle.GeneralTextColor = workPart.Colors.Find("Black")
draftingNoteBuilder14.Style.LetteringStyle.GeneralTextFont = 2
Dim fontIndex14 As Integer
fontIndex14 = workPart.Fonts.AddFont("ge_font5")
Dim assocOrigin14 As Annotations.Annotation.AssociativeOriginData
assocOrigin14.OriginType = Annotations.AssociativeOriginType.Drag
Dim nullView14 As View = Nothing
assocOrigin14.View = nullView14
assocOrigin14.ViewOfGeometry = nullView14
Dim nullPoint14 As Point = Nothing
assocOrigin14.PointOnGeometry = nullPoint14
assocOrigin14.VertAnnotation = Nothing
assocOrigin14.VertAlignmentPosition = Annotations.AlignmentPosition.TopLeft
assocOrigin14.HorizAnnotation = Nothing
assocOrigin14.HorizAlignmentPosition = Annotations.AlignmentPosition.TopLeft
assocOrigin14.AlignedAnnotation = Nothing
assocOrigin14.DimensionLine = 0
assocOrigin14.AssociatedView = nullView14
assocOrigin14.AssociatedPoint = nullPoint14
assocOrigin14.OffsetAnnotation = Nothing
assocOrigin14.OffsetAlignmentPosition = Annotations.AlignmentPosition.TopLeft
assocOrigin14.XOffsetFactor = 0.0
assocOrigin14.YOffsetFactor = 0.0
assocOrigin14.StackAlignmentPosition = Annotations.StackAlignmentPosition.Above
draftingNoteBuilder14.Origin.SetAssociativeOrigin(assocOrigin14)
Dim point14 As Point3d = New Point3d(92, 26, 0.0)
draftingNoteBuilder14.Origin.Origin.SetValue(Nothing, nullView14, point14)
Dim nXObject14 As NXObject
nXObject14 = draftingNoteBuilder14.Commit()
draftingNoteBuilder14.Destroy()
Is possible that some lines are missing but the code works.
RE: Create Notes, a simple way?
Take that chunk of code and turn it into a subroutine or function that you can call multiple times from Sub Main.
Here's a function example that takes the note text, x coordinate, and y coordinate as parameters:
CODE
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim workPart As Part = theSession.Parts.Work
    Sub Main()
        Dim myNotes(9) As NXObject
        Dim i As Integer = 0
        For i = 0 To 9
            myNotes(i) = AddNote("Note number: " & i.ToString, i, i)
        Next
    End Sub
    Function AddNote(ByVal noteText As String, ByVal Xposition As Double, ByVal Yposition As Double) As NXObject
        Dim nullAnnotations_SimpleDraftingAid1 As Annotations.SimpleDraftingAid = Nothing
        Dim draftingNoteBuilder1 As Annotations.DraftingNoteBuilder
        draftingNoteBuilder1 = workPart.Annotations.CreateDraftingNoteBuilder(nullAnnotations_SimpleDraftingAid1)
        draftingNoteBuilder1.Origin.Plane.PlaneMethod = Annotations.PlaneBuilder.PlaneMethodType.XyPlane
        draftingNoteBuilder1.Origin.SetInferRelativeToGeometry(False)
        draftingNoteBuilder1.Origin.SetInferRelativeToGeometry(True)
        draftingNoteBuilder1.Origin.Anchor = Annotations.OriginBuilder.AlignmentPosition.BottomLeft
        text14(0) = noteText
        draftingNoteBuilder1.Text.TextBlock.SetText(text14)
        draftingNoteBuilder1.Style.LetteringStyle.GeneralTextSize = 1.3129
        draftingNoteBuilder1.Style.LetteringStyle.GeneralTextCharSpaceFactor = 0.8945
        draftingNoteBuilder1.Style.LetteringStyle.GeneralTextAspectRatio = 0.8945
        draftingNoteBuilder1.Style.LetteringStyle.GeneralTextColor = workPart.Colors.Find("Black")
        draftingNoteBuilder1.Style.LetteringStyle.GeneralTextFont = 2
        Dim fontIndex1 As Integer
        fontIndex1 = workPart.Fonts.AddFont("ge_font5")
        Dim assocOrigin1 As Annotations.Annotation.AssociativeOriginData
        assocOrigin1.OriginType = Annotations.AssociativeOriginType.Drag
        Dim nullView1 As View = Nothing
        assocOrigin1.View = nullView1
        assocOrigin1.ViewOfGeometry = nullView1
        Dim nullPoint1 As Point = Nothing
        assocOrigin1.PointOnGeometry = nullPoint1
        assocOrigin1.VertAnnotation = Nothing
        assocOrigin1.VertAlignmentPosition = Annotations.AlignmentPosition.TopLeft
        assocOrigin1.HorizAnnotation = Nothing
        assocOrigin1.HorizAlignmentPosition = Annotations.AlignmentPosition.TopLeft
        assocOrigin1.AlignedAnnotation = Nothing
        assocOrigin1.DimensionLine = 0
        assocOrigin1.AssociatedView = nullView1
        assocOrigin1.AssociatedPoint = nullPoint1
        assocOrigin1.OffsetAnnotation = Nothing
        assocOrigin1.OffsetAlignmentPosition = Annotations.AlignmentPosition.TopLeft
        assocOrigin1.XOffsetFactor = 0.0
        assocOrigin1.YOffsetFactor = 0.0
        assocOrigin1.StackAlignmentPosition = Annotations.StackAlignmentPosition.Above
        draftingNoteBuilder1.Origin.SetAssociativeOrigin(assocOrigin1)
        Dim point1 As Point3d = New Point3d(Xposition, Yposition, 0.0)
        draftingNoteBuilder1.Origin.Origin.SetValue(Nothing, nullView1, point1)
        Dim nXObject1 As NXObject
        nXObject1 = draftingNoteBuilder1.Commit()
        draftingNoteBuilder1.Destroy()
        Return nXObject1
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
Thanks cowski, this is great but how could be adapted when the notes have different X and Y positions and style?
The function takes X and Y positions as parameters, pass in whatever you want for each note. Any other text properties that you want to control (text height, font, etc) can be turned into parameters similar to what was done for the noteText, Xposition, and Yposition.
Ok, I will work on this, thanks for your help!!
