Parameters in BOM Balloons not in Repeat Region
I am working on updating our Pro E standards at my company to fully utilize the parametric ability of the software and have come across a small hiccup. I have created two parameters in each start part called “PID_TOP” and “PID_BOTTOM”. The intent of these string parameters is to hold the equipment information that is on the P&ID. This makes our P&ID and fabrication drawings more closely tied to each other and helps bridge the gap between mechanical and controls. I have also created custom BOM balloons that can be used by selecting “Alt Symbol” under Table > BOM Balloons and is set to display the values of the two PID string parameters I created in a symbol that is identical to the P&ID.
My problem comes in when I add these balloons to a drawing. The only way I can get these string parameters to fill in correctly in my balloon is to add two columns to my repeat region and have them report “&ASM.MBR.PID_TOP” and “&ASM.MBR.PID_BOTTOM”. This is undesired as my BOM is becoming pretty wide already and is taking up valuable space on the drawing and in a typical fab drawing for a fluid skid there are usually 100+ components while only a handful of components with P&ID tags meaning I would create two columns of mostly dashes. I tried simply adding them as local parameters under Table > Repeat Region > Relations but it didn’t work. Can anyone offer a suggestion as to how I can make this work or am I stuck with just having to add the columns to my BOM?
Thank you in advance
Steven
Steven
RE: Parameters in BOM Balloons not in Repeat Region
I know it's a hack but I've seen worse.
