Gage or gauge?
Gage or gauge?
Gage or gauge?
For gage (gauge) dimensions on a drawing, what is the correct spelling of "gage"?
RE: Gage or gauge?
In the US, they are both acceptable spellings and both are widely used.
RE: Gage or gauge?
I'm British and always use "gauge".
RE: Gage or gauge?
As an old USA stress guy, when I see "Gage" that means strain gage to me and when I see "Gauge" that means a pressure gauge. To other different-types of engineering guys, here and there,it may mean something different. Good huntings. [bigsmile]
RE: Gage or gauge?
Both are correct. Pick one and stick with it. Inconsistency is the only way you can mess it up.
RE: Gage or gauge?
When I see "gage" my brain drops the "e". Can't help it. Always want to know why a gag is installed there. Consequently I always use "gauge".
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
RE: Gage or gauge?
I have always used gauge but my context is mostly in sheet and coil gauges.
-Bill
RE: Gage or gauge?
Bill's answer caused me to think a bit harder. For sheet metal and wire sizes, I have only ever seen gauge. For measuring instruments I have seen both spellings.
RE: Gage or gauge?
Thanks to all!
RE: Gage or gauge?
Just use English (gauge) no mistakes or misunderstanding.
RE: Gage or gauge?
humour or humor ?
color or colour ?
tomaytoe, tomartoe
RE: Gage or gauge?
America and England; two country separated by a common language.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Gage or gauge?
per the dictionary . . .
gauge
noun \ˈgāj\
Definition of GAUGE
1
a : a measurement (as of linear dimension) according to some standard or system: as (1) : the distance between the rails of a railroad (2) : the size of a shotgun barrel's inner diameter nominally expressed as the number of lead balls each just fitting that diameter required to make a pound <a 12-gauge shotgun> (3) : the thickness of a thin material (as sheet metal or plastic film) (4) : the diameter of a slender object (as wire or a hypodermic needle) (5) : the fineness of a knitted fabric expressed by the number of loops per unit width
b : dimensions, size
c : measure 1 <surveys are a gauge of public sentiment>
2: an instrument for or a means of measuring or testing: as
a : an instrument for measuring a dimension or for testing mechanical accuracy
b : an instrument with a graduated scale or dialect for measuring or indicating quantity
3: relative position of a ship with reference to another ship and the wind
4: a function introduced into a field equation to produce a convenient form of the equation but having no observable physical consequences
gage
noun \ˈgāj\
Definition of GAGE
1: a token of defiance; specifically : a glove or cap cast on the ground to be taken up by an opponent as a pledge of combat
2: something deposited as a pledge of performance
"gauge" is correct.
RE: Gage or gauge?
Provided you are speaking "English"
RE: Gage or gauge?
Consider also the following terms and their meanings:
• gauge boson, gauge group, gauge invariance, gauge particle, gauge theory, gauge transformation;
• gage block, gage brick, gage cock, gage glass, gage length, gage loss, gage penetration, gage plate, gage point, gage pressure;
as used by different branches of science and engineering.
RE: Gage or gauge?
Consistency is all.
The English English "gauge" isn't even pronounced as spelled. Similarly, the American English "gage" isn't either.
How would a new word to represent that sound be spelled? "gaydge" perhaps.
- Steve
RE: Gage or gauge?
... I take that back. Compared with "rage", "page", "wage", the American spelling seems more sensible.
- Steve
RE: Gage or gauge?
"Gage" strikes me like something cutsie, like "thru" instead of "through" or "valu" instead of "value".
It doesn't take that long to type one extra letter!
RE: Gage or gauge?
When the unit of measure is taken by direct reckoning, I use gage. When there's a dial or something else that moves in response to external force (or stress) I use gauge. So, a stream gage is different than an earth-pressure gauge. The USGS went with gage for water level measurement devices several decades ago.
f-d
¡papá gordo ain’t no madre flaca!
RE: Gage or gauge?
I have always used gage as a verb, as in to estimate or evaluate something; whereas gauge is a noun. In this case gauge would be the correct form of the word.
RE: Gage or gauge?
Quote (somptinggGuy)
"gaydge" perhaps
what about geige? as in beige?
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: Gage or gauge?
No, Walter, "beige" ends with an "sh" sound.
RE: Gage or gauge?
Geige can never sound like guage.
RE: Gage or gauge?
I honestly have no idea how I would pronounce guage.
gwaag?
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
RE: Gage or gauge?
To the quotes from the dictionary...selective quoting is common in the press, but engineers know better. :) Definition 2 of dictionary.com shows they are equal. Same for definition 3 on Meridian-Webster...and many others.
http://dictionary.reference.com/browse/gage?s=t
http://www.merriam-webster.com/dictionary/gage
Matt Lorono, CSWP
Product Definition Specialist, DS SolidWorks Corp
Personal sites:
Lorono's SolidWorks Resources & SolidWorks Legion
RE: Gage or gauge?
I prefer to alternate the spellings to confuse the reader. smile
I generally agree with PMOVER's post. However, my vintage 1976 Webster's New Collegiate Dictionary also indicates that "gage" is a variant of "gauge". This means that either spelling is OK but "gauge" is prefered. One of the other definitions of "gage" is "greengage", which is a type of plum.
In my construction contract documents, I generally avoid specifying plums and tokens of defiance, so I use gauge.
--Winston S. Churchill
RE: Gage or gauge?
You use a pressure gauge to measure a gage pressure...
