ball bearing with a flat?
We are looking to use a bearing ball with a flat on it with a depth of less than the radius of the ball. I am wondering if there are already something out there we can use? I can make a few by clamping them in a collet and grinding/machining it down but this would be expensive on a mass production basis. We might be even able to change the design to a plastic like delrin. The surface finish and roundness is important because it will be used to seat against a cone seat for a valve.
RE: ball bearing with a flat?
You do know a bearing ball can't serve as a bearing ball if it can't roll right? (you probably do, but I just thought I'd mention it...)
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Bruce
www.accuratus.com
