Low thermal conductivity, high temperature plastic
I need a materials for a small flexure with very low thermal conductivity that will survive +250C and have maximum strength. Also need to provide discharge path for static electricity and be machinable.
Suggestions please.
RE: Low thermal conductivity, high temperature plastic
Is the 250C wet or dry environment.
How many hours does it need to withstand 250C
If it's dry and not for to long, I think glass and high surface area carbon black or stainless steel fibre filled heat stabilised nylon 4.6 could be OK
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
A 30% Carbon fibre filled PEEK has max service temp (air) of 340ºC. It will also be much more than static conductive. The thermal conductivity will be up (compared to unfilled) due to the carbon fibre - 0.92W/m-K
It's also expensive....sad
H
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
