Is it possible changing all dimensions proportionally?
I create a 3D drawing, but all parts are very small. So, I would like to give every part their right dimensions. Is it possible? How? Or do I need to redo the designs, changing one by one?
RE: Is it possible changing all dimensions proportionally?
If you don't mind loosing your feature tree (synchronous?), here is something you can do:
- create a new ordered part
- 'part copy' (as construction) of the assembly with the chosen scale factor
- save as x_t (options: check construction bodies)
- reopen that x_t file as an assembly
It solves the question.
As I'll lose the feature tree, then I do it when I finish all drawings. Then, I build a new assembly.
Thanks.
