CALCULATION OF THE FLOATING HEAD CONFIGURATION OF SPLIT RING TYPE D
Hi all,
I have to check an existing heat exchanger type AES with the configuration type D of split ring. I know that TEMA indicates two equations for shear and bending. I would like to know when it's usefull this kind of split ring and how calculate the value of W.
Thanks in advance.
Thanks in advance.
RE: CALCULATION OF THE FLOATING HEAD CONFIGURATION OF SPLIT RING TYPE D
