max distance constraint?
Hello
When applying assembly constraints...
Where is the maximum distance option?
The distance constraint is a minimum distance but, what if I want to use a a range of movement, specifying a max and min distance?
RE: max distance constraint?
It's not actually a 'Minimum' Distance, but rather a simple 'Fixed' Distance constraint. And NO, there is no actual Maximum (or Minimum) Distance Assembly constraint.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK thanks
