using a cellphone signal booster
I live in the Philippines and am using the zBoost YX-520I cellphone signal booster to boost our GSM and (900 MHz) and DCS (1800 MHz) in our home. The device uses an omni directional dipol aerial (outdoor) antenna and an omnidirectional whip base (indoor) antenna. As we may have all known both of these antennas have a gain of 1 (o dBi). I get a fairly 3-4 bar signal in the house but I want to extend the coverage of the booster. According to its specs the amplifier base unit has a 50dB ADAPTIVE gain and a 100mW RF Output Power. I am planning to "upgrade" both antennae for them to have gains and can probably increase coverage. These are my questions:
1.) The amplifier, being an adaptive kind, has automatic gain control. As I understand with this, the output level of the amplifier (before it is propagated by the indoor antenna) will stay the same (because the amp adjusts the gain for weak or strong signals) as long as the outdoor signal is not extremely low. So I'm wondering if using a Yagi/Log Periodic antenna for the outdoor antenna will increase the total signal gain of the system?
2.) Conversely, would using an indoor antenna with a gain>1 increase coverage?
3.) What does the RF Output Power of 100mW in the specs represent? Does that mean that the power fed to the indoor antenna is always 100mW? I thought that it depends on how strong is the captured signal of the outdoor antenna?
4.) If I upgrade the antennae of the system, impedance matching is very important. How would I know what impedance (50/75 Ohm) would I get in looking for these two antennae? Do I need to test the input and output ports of the amp? How do I know the characteristic impedance of the RG59 cable that I'm currently using if I also decide to replace this with a better coax cable like RG6?
Sorry for all these questions. I'm really interested in getting this done. I'm a licensed Electronics Engineer but haven't quite practiced my profession on antenna signal propagation yet. I learned all of this way back in College but I already forgot most of the concepts. I hope you guys can help me here.
Thank you very much in advance :) Peace!
RE: using a cellphone signal booster
Moreover, you posted on a weekend. As this is primarily a work-related site, and most engineers here work, they're probably less likely to respond over a weekend.
TTFN
Your question 3 is answered by your question 1.
RG59 and RG6-type are both 75-ohms and both use (TV type) F-connectors. Upgrading to RG-6 would probably make only a tiny difference (assuming reasonable cable lengths).
You could cover a larger area by installing the system off to one side and using a high gain antenna aimed to the coverage area from one side. The dual band would complicate this.
A corner reflector could be built with cardboard and aluminum foil to provide increase gain (on the order of +10-15 dBi), perhaps even using the supplied whip as the driven element.
With your last two phrases above, are you referring to upgrading the base station antenna and increase the gain by using corner reflectors?
TTFN
If so, replacing the outside antenna with an antenna with better gain is just useless?
TTFN
I would think that a Log Periodic outdoors would do better than this antenna. A yagi is a higher gain Log Periodic and better.
The Yagi is poorly named, Professor Yagi took the credit, but his studendt Uda did all the work. My Antenna professor in 1979 said to spread the word. Taking proper amount of credit won't get you pummelled for decades.
http://www.wpsantennas.com/high-gaindirectionalyag... just some examples.
Make sure it's both bands, tx and rx.
to save money, you could bend some metal (chicken wire) and make a reflector antenna out of your rooftop antenna. Using a Direct TV dish might be a good start (though that's an offset reflector). The wind is a challenge though.
Good luck,
