Queries with Extrude Command
Hi, I am doing UG NX Customisation and I need to integrate Extrude Command into some other command. I am using UF_MODL_create_extruded to create the extruce but I need few more knowledge how to give user some more flexibility like given in Extrude Command UI. They are -
1. How do I give options like Symmetrical/Value etc in Start/End? Is there any option in Block Styler?
2. How do I add the handler to Start and End Distance. Like when I drag it the values are getting changed and the extrude is getting updated. How can I listen to a mouse move event?
3. How to show the preview in run time?
UG NX Programming team, kindly help!
