Block S32 Undefined
Block S32 Undefined
I am new to using AutoCAD and was only using it to modify a DXF which had different notes on different layers to be created and modified. Easy enough.
After several hours of work, there are a lot of notes, the layers started acting funny. The lightbulb next to the layer was not changing when a layer was turned off or on. Suspecting something wasn't right I saved my work, restarted the program and tried to get back to work. However now the dxf won't load.
On the screen it says "Press Enter to Continue" and at the bottom it says "Error S32 Undefined". When you hit enter it closes the file, not that it has really opened the file, and sits ready for the next command.
It will open other files without a problem, both DXFs and DWGs.
This is a rush project and any help anyone can give would be greatly appreciated. Thanks in advance.
Info:
Operating System: Windows 7 Professional
AutoCAD version: 2012
Info:
RE: Block S32 Undefined
The recover option gives me the same error. Its exact phrasing is as follows:
Error: Block "*S32" was not defined
Invalid or incomplete DXF input -- drawing discarded.
Use the command DXFIN to load your dxf file
See what happens
Best to you,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
