pressure control algorithm (to maintain target strain rate) in simulating superplastic forming
Hi
I intend to do my thesis on simulating superplastic forming process using Abaqus. I’m new to this software and the Abaqus user’s manual is not that useful for me. I’m having a problem finding Abaqus built-in pressure control algorithm option to maintain a target strain rate.Actually I can’t find this option in the Abaqus GUI.I would appreciate it if you could kindly help me.
(please find attached the pdf file concerning this built-in algorithm)
regards
regards
RE: pressure control algorithm (to maintain target strain rate) in simulating superplastic forming
If you are comfortable with FEA, all you need to do is install Microsoft Visual Studio, Intel Fortran Compiler and ABAQUS on your machine and start coding! Dassault Systeme website has all the required information regarding version compatibility. You may need to uninstall ABAQUS completely before installing VS and Fortran compiler. As I mentioned, the installation sequence is important (VS -> Fortran Compiler -> ABAQUS).
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
