Where is the Express tools?
Hey been hearing alot about the AutoCad 2000 express tools, but don't seem to have it. Also heard that its downloadable free over the internet.
Anyone know where i can get this set of tools for free ?
Daniel
RE: Where is the Express tools?
Dear danieldoral,
When you upgrade from AutoCAD 2000 to AutoCAD 2000i or AutoCAD 2002, you can use one of the following methods to migrate the Express Tools Library.
Method #1
Install AutoCAD 2000i before you uninstall AutoCAD 2000 to ensure that Express Tools migrate into AutoCAD 2000i or AutoCAD 2002.
Method #2
Create a backup of the Express Tools Library before you install AutoCAD 2000i or AutoCAD 2002. Use this method if you need to completely uninstall AutoCAD 2000 before you install AutoCAD 2000i or AutoCAD 2002.
Use this procedure to back up the Express Tools library and then migrate the files to AutoCAD 2000i or AutoCAD 2002.
1.    Before uninstalling AutoCAD 2000, make backup copies of the following Express Tools-related files:
o    express\*.*
o    support\acettest.fas
o    help\acetmain.hlp
o    help\acetmain.cnt
o    help\acetfaq.hlp
2.    Install AutoCAD 2000i or AutoCAD 2002, and reboot your computer.
3.    Under the directory where you installed AutoCAD, create a subdirectory named Express. For example, if you installed AutoCAD on the C drive in the c:\program files\autocad 2000i directory, create the following directory: c:\program files\autocad 2000i\express.
4.    Copy all of the Express Tools files from the express\*.* file that you backed up in step 1 into the new directory you created in step 3.
5.    Copy the acettest.fas file to the AutoCAD support files subdirectory. For example, if you installed AutoCAD on the C drive in the c:\program files\autocad 2000i directory, the support files directory would be c:\program files\autocad 2000i\support.
6.    Copy the acetmain.hlp, acetmain.cnt, and acetfaq.hlp files to the AutoCAD Help subdirectory.
7.    On the command line, type appload and press ENTER.
8.    Under Startup Suite, select Contents and choose Add.
9.    Select the acettest.fas file in the AutoCAD support directory. This will cause this file to load every time AutoCAD is started. You may have to restart AutoCAD at this point.
10.    Type expressmenu on the command line.
Note: The directories may vary slightly depending on the version of AutoCAD and the folders specified during the install.
The Express Tools menu will load automatically in AutoCAD 2000i or 2002 and the tool kit will be ready to use.
Warning: The Express Tools have not been fully tested with AutoCAD 2000i or 2002.
Farzad
