Anchor Bolt Shear Design
Does compress check anchor bolts for wind or seismic shear? There is no input for anchor bolt allowable shear stress and I don't see the calculation in the reports.
RE: Anchor Bolt Shear Design
Yes, COMPRESS checks this condition.
There actually IS an input on ths saddle design dialog for the anchor bolt allowable shear stress. And the bolt shear stress calculation is shown under the bold caption "Shear stress in anchor bolting"
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
