Arrangement configuration
I have a water tank assembly that uses an arrangement, but I'm having an issue with it.
The tank lid sub-assy has a elbow fitting that swivels. I created several arrangements to have the elbow fitting pointing in several directions. The tank lid sub-assy then goes into the tank assy. The problem is that the tank is used in several different units and if I change the arrangement in one unit, then it will be like that in the others. Is there a way to set up the arrangement and not not have to change it whenever I open the unit?
Thanks!
Al
RE: Arrangement configuration
BTW, I'm using NX 7.0.1.7 & Teamcenter Express on Windows 7.
Thanks again!
Al
Arrangements are assembly specific, which means that it will always revert to the default and must be specifically set in each Assembly where that sub-assembly is used. In other words, it's NOT the sub-assembly which remembers which Arrangement to use, but rather the next level-up Assembly, where the sub-assembly is being used, this is where you make the selection as to which Arrangement you wish to see in effect. That information is then stored in that top-level assembly.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
You can also "overide position" from your main assembly...
