Concrete crushing model
Hi all!
I'm an engineering student and I'm new to ANSYS. I've to do a fem analysis for my thesis.
What I've to model is the breaking of a concrete block.
My problem is that I want to do an axisymmetric model and then display the cracking
and crushing lines.
I've found in some tutorials that the only way to model concrete's breaking is using SOLID65 which hasn't got the axisymmetric option. Have I understood right?
In case SOLID65 isn't usable in axisymmetric mode, can I use another element type in axisymmetric mode?
Can you please help me also with some information about modeling concrete material?
Thanks a lot,
RE: Concrete crushing model
Yep afraid so. SOLID65 is the only element available with the concrete option for crushing and cracking. Therefore if you want to model with axisymmetric elements you can do this in ansys but you won't be able to have concrete crushing and cracking. However, if your model has lines of symmetry (and your loading is axisymmetric - this is important) you may be able to take advantage of this and create a reduced solid model with appropriate symmetry boundary conditions which will help reduce your model size.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Dear Drej, your comment is very clear and helpfule, thanks a lot
Hi Drej,
I reply this post just try to find you (Drej). I found you replied and provided a very useful macro to make a helical spring. It is very impressive (thread569-124712: copper coil around a shaft, macro(2)).
I do have a few question to ask you.
1) how to put a non-coil end at each end (see the attachment)? It also need to be meshed correctly.
2) how can I apply load so one end will rotate relative to the other end? I would like to know circumferential strain on the inner and outer surface of the turns under this pure rotation. I do not sure how to express the circumferential strain either.
I am new to Ansys. You are expert. Please help.
Thanks a million.
Steve
p.s. here is my email: country_roadhe@hotmail.com
How we can have varies tensile/compressive strength varies with temperature in SOLID65?
I want to add the properties in workbench/simulation by adding a command under geometry.
