Need Help with Error while Opening .prt Files ????
I sometimes have to download files from other sources/companies etc. Every once in a while when I try to open a file that I have downloaded I get this message:
http://imgur.com/fZRMh
I can't seem to figure out what this message is and why it shows up for only random files. Has anyone ever seen this message or can anyone give me some advice why this is happening?? Your information would be greatly appreciated because this is causing me major problems at the moment.
Andrew
Andrew
RE: Need Help with Error while Opening .prt Files ????
Chris T.
Project Design Analyst
Kohler Co. Engine Division
Using NX6
www.nxjournaling.com
http://files.engineering.com/getfile.aspx?folder=7...
If you are sure it is an NX file, you can use the command line utility ug_inspect.exe (found in the UGII folder of your NX install) to scan for part corruptions. Open a command window and the syntax would be:
<path to UGII folder>\ug_inspect.exe -scan <path to your .prt file>
if you are able to see text then maybe post the first 5-6 llines of what you get.
Chris T.
Using NX6
Ben Loosli
Please run ug_inspect and post the results.
Mark Rief
Product Manager
Siemens PLM
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
