Boiler Room Design for Blast
I am a structural engineer and have been tasked with the design of a boiler room. I was told by the architect/contractor that the room needed to have blow out panels in the wall for an explosion. I was also told that this was an insurance requirement based on the ASME Boiler and Pressure Vessel Code. In searching the internet I can find nothing that talks at all about designing a boiler room for any sort of blast pressure and being a structural engineer I am not familiar with the ASME Boiler and Pressure Vessel Code.
Is anyone aware of any requirements in the ASME BPVC for the design of boiler rooms for explosions/blast? If so, could you point me to the code section that talks about this?
If it helps according to the boiler specs it is an ASME Section I (Power Boiler) with natural gas as the fuel.
RE: Boiler Room Design for Blast
There may be building codes that call for this.
And then there are insurance companies.
I have often seen the upper half of an outer wall installed as a curtain wall.
Not only do you get blast relief but you also get access for future work.
Plymouth Tube
There is NFPA 68 which has complete coverage on the subject.
Also take a look at the following website:
http://www.zookdisk.com/pdf_files/7000%20-%20CV%20...
I hope it helps.
