Hello, I have selected all nodes
I have selected all nodes with z coordinate equal to -0.2:
A=NSEL,S,LOC,Z,-0.2
I want to save the node numbers on a array, and then calculate the maximum Z displacement on the group of nodes.
Any help appreciated,
Hugo Silva
Mechanical Eng. PhD student
Materials Eng. MSc.
RE: Hello, I have selected all nodes
look at those commands :
*dim to create a array parameter
*vget to retrieve values and stores them in a array parameter
*do (do loop )
*get to get the loc z for each node of the table
*endo
and then find the max
or directly
NSEL,S,LOC,Z,-0.2
*GET, Parameter_name , node , 0, mxloc, z
hope it helps
oh sorry directly way is a mistake, i mixed stuff
I can select all nodes that I want.
NSEL,S,LOC,Z,-0.2
I want to get the maximum nodal z displacement in my node selection.
Can you tell me how? I tried to use the *GET command, but with no sucess.
I say the other thread, It could not help me either.
Hugo Silva
Materials Eng. MSc.
I´m looking for the correct sintax of the *GET command, or any other command that can do what i´m looking for.
Hugo Silva
Materials Eng. MSc.
