catdrawing file size
i need to work on a drawing that as been separated in 3 since the file was to big.
i'm trying to reduce the files sizes so i can make it one drawing again.
is there any way to "purge" or "delete useless element" in catdrawing????
i already done Q-checker and Catdua, reduzing the size from 115k to 95k.
any other way, macros, tools that i dont know?
thanks for any help!
happy halloween!!!
RE: catdrawing file size
i already done Q-checker and CatduaV5, reduzing the size from 115k to 95k.
SORRY winky smile
pls tell me their is something else i can do !
Sorry, I realized late that you run CATDUAV5.
Probably you have a lot of links with 3D, maybe also 2D components, hatches or other elements like those ones. But...are you taking about Mb or kb ? Because what you consider to be so big should be Mb...
Did you tried a save as (new name) just to see what is going on? Or copy-paste the views in a new drawing and then save?
Unfortunately I don't know if you have other options.
Fernando
https://picasaweb.google.com/102257836106335725208
Hi Ferdo,
yes, but my compagny limitation enable me to break them by any means, even those corrupted ones.
I've try many combination with those (expose/explode)
what???
dwg was originaly 700,000 kb, had to be divided in 3 dwg size the dwg was superior to 200,000kb , witch is my compagny limitation for one dwg
I've been succefull so far to reduce one of those ( from 135,000 kb to 95,000 kb), but still need some work
tks again for any help
