Catia - copy-paste-body
Hello to all,
I have macro for copying bodys from selected parts to target part (it also publicate bodys inside all selected parts and paste with link into target part do assamble and symmetry)
So at the end it creates symmetry of product but in part.
I am new to catia vba and all of this code is combined from diferent macros :)
Problem is with instances . it copy all instances at th same place.
I hope someone could help me with this, a am ata the wall :)
Here is my code and shema of my product.
thanks in advance
Sub CATMain()
On Error Resume Next
Dim ActiveDocument1 As Document
Set ActiveDocument1 = CATIA.ActiveDocument
If Err.Number <> 0 Then
' in case no open document was found
'''Err.Clear
Call MsgBox("No document was found.", _
vbCritical + vbOKOnly, "Error")
Exit Sub
End If
Dim Selection1 As Selection
Dim sel As Selection
Dim cSelection 'As Selection
Dim cSel As Selection
Dim oProd As Product
Dim oObject As Object
Dim Sa As String
Dim i As Integer
Dim n As Integer
Dim V As Integer
Dim targetPart As String
Dim StatusPart As String
Dim Status As String
Dim InputObjectType(0)
Dim srcDoc As PartDocument
Dim srcPart As Part
Dim srcPart2 As Part
Dim body1 As Body
Dim B As Integer
Dim Bodies1 As Bodies
Dim GBool As Boolean
Dim NBool As Boolean
Set Selection1 = ActiveDocument1.Selection
Set sel = ActiveDocument1.Selection
V = Selection1.Count
If Selection1.Count = 0 Then
MsgBox "Markieren Sie die Teile zum kopiren:" & vbCrLf, vbCritical
Exit Sub
End If
If Selection1.Count2 > 0 Then
For D = 1 To Selection1.Count2
Set oObject = Selection1.Item(D).Value
Select Case Selection1.Item(D).Type
Case Is = "Product"
MsgBox oObject.Product
Case Else:
MsgBox "Nur die Teile Markiren!"
Exit Sub
End Select
Next D
Else
MsgBox "Teile Markieren:" & vbCrLf, vbCritical
Exit Sub
End If
'MsgBox V
'Exit Sub
If Selection1.Count <> 0 Then
Dim product1 As Product
Dim strFriends(0 To 200) As String
For i = 1 To Selection1.Count
Set product1 = Selection1.Item(i).Value
strFriends(i) = product1.PartNumber
StatusPart = ""
Set srcDoc = CATIA.Documents.Item(strFriends(i) & ".CATPart")
StatusPart = srcDoc.Name
If StatusPart = "" Then
MsgBox "Nur die Teile Markiren!", vbInformation, "Error"
Exit Sub
End If
Next
Dim oDoc1 As Document
Set oDoc1 = CATIA.ActiveDocument
MsgBox "Catpart wählen:"
Set cSelection = oDoc1.Selection
cSelection.Clear
InputObjectType(0) = "AnyObject"
Status = cSelection.SelectElement2(InputObjectType, "Select an Element", True)
If (Status = "Cancel") Then
MsgBox "CATPart nicht gewählt!", vbInformation, "Error"
Exit Sub
Else
Set oObject = cSelection.Item(1).Value
cSelection.Clear
targetPart = oObject.Name & ".CATPart"
Dim Startabfrage As Integer
Startabfrage = MsgBox("Gewähltes Catpart nahmen? " & targetPart, 1 + 64, "")
If Startabfrage = 2 Then
Exit Sub
End If
' For i = 1 To V
' Set srcDoc = CATIA.Documents.Item(strFriends(i) & ".CATPart")
' srcDoc.Activate
' Set srcPart = srcDoc.Part
' Set Bodies1 = srcPart.Bodies
' For B = 1 To srcPart.Bodies.Count
' If Bodies1.Item(B).InBooleanOperation = False Then
' Set body1 = Bodies1.Item(B)
' GBool = False
' Set documents1 = CATIA.Documents
' Set partDocument1 = documents1.Item(strFriends(i) & ".CATPart")
' Set product5 = partDocument1.GetItem(strFriends(i))
' Set reference1 = product5.CreateReferenceFromName(strFriends(i) & "/!" & body1.Name)
' Set publications1 = product5.Publications
' For Z = 1 To publications1.Count
' 'MsgBox publications1.Item(Z).Name
' If publications1.Item(Z).Name = body1.Name Then
' GBool = True
' End If
' Next Z
' If GBool = False Then
' Set publication1 = publications1.Add(body1.Name)
' publications1.SetDirect body1.Name, reference1
'' End If
' End If
' Next
' Next
Dim NazivBody As String
Dim NazivBody1 As String
Dim TV As Integer
For i = 1 To V
srcDoc.Activate
GBool = False
NBool = False
NazivBody = body1.Name
If Len(body1.Name) > 8 Then
If Right(body1.Name, 8) = "PartBody" Then
body1.Name = body1.Name & "1"
NBool = True
End If
End If
GBool = True
End If
Next Z
End If
If NBool = True Then
body1.Name = NazivBody
End If
sel.Clear
sel.Add Bodies1.Item(B)
sel.Copy
Dim targetDoc As PartDocument
Set targetDoc = CATIA.Documents.Item(targetPart)
sel.Clear
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Set srcPart2 = targetDoc.Part
sel.Add srcPart2
sel.PasteSpecial ("CATPrtResult")
srcPart2.Update
'MsgBox body1.Name
End If
Next
Next
' MsgBox targetDoc.Name
targetDoc.Activate
Set srcPart = targetDoc.Part
n = Bodies1.Count
Set body1 = Bodies1.Item("PartBody") 'The fisrt body of my CATPart
Dim shapeFactory1 As Factory
Set shapeFactory1 = srcPart.ShapeFactory
For i = 2 To n
If Bodies1.Item(i).InBooleanOperation = False Then
srcPart.InWorkObject = body1
Dim body2 As Body
Set body2 = Bodies1.Item(i)
Dim assemble1 As Assemble
Set assemble1 = shapeFactory1.AddNewAssemble(body2)
End If
Next
srcPart.UpdateObject assemble1
srcPart.Update
Dim Symmetry1 As Symmetry
Set Symmetry1 = shapeFactory1.AddNewSymmetry2(body1)
srcPart.UpdateObject Symmetry1
srcPart.Update
MsgBox "Fertig"
End If
End If
End Sub
thanks in advance
Sub CATMain()
'''Err.Clear
Exit Sub
End If
Dim Sa As String
Dim i As Integer
Dim n As Integer
Dim V As Integer
Dim srcPart As Part
Dim body1 As Body
Dim B As Integer
Exit Sub
End If
Case Is = "Product"
Case Else:
Exit Sub
End Select
Next D
Else
Exit Sub
End If
'MsgBox V
'Exit Sub
StatusPart = ""
Exit Sub
End If
Next
cSelection.Clear
Exit Sub
Else
cSelection.Clear
Exit Sub
End If
' For i = 1 To V
' srcDoc.Activate
' GBool = False
' GBool = True
' End If
' Next Z
'' End If
' End If
' Next
' Next
Dim TV As Integer
For i = 1 To V
srcDoc.Activate
GBool = False
NBool = False
NBool = True
End If
End If
GBool = True
End If
Next Z
End If
End If
sel.Clear
sel.Copy
sel.Clear
sel.Add srcPart2
srcPart2.Update
'MsgBox body1.Name
End If
Next
Next
targetDoc.Activate
n = Bodies1.Count
For i = 2 To n
Dim body2 As Body
End If
Next
srcPart.Update
srcPart.Update
MsgBox "Fertig"
End If
End If
End Sub
RE: Catia - copy-paste-body
Is there anyone who can help me with this please.
Maybe my question is not well writen,i have problems to copy body of parts that are the same in product (instance of part on diferent place)
I can copy bodys of all instances but in same place (i need them on there place in assembly)
I suppose you don't want to use Generate CATPart from Product functionality....
Fernando
https://picasaweb.google.com/102257836106335725208
You are right i dont wont to have allcatpart generated from catia becouse i need something like allcatpart but all bodys must have link to original.
Purpose of this macro is to make symmetry of product but with live links so changes on orginal product will afect this symmetric part.
my macro allready doo almost everithing, but i have problems when one part have more instances, then macro copy all instance bodys on one place.
Without sample files it will be dificult to test, I believe not everyone has time to recreate the scenario. And there is also a problem of the CATIA version for those which will want to test it (I'm stuck in r18 for example).
Fernando
do you know name of that function, i did not know that this funktion is exsisting??
Also thanks to ferdo for helping me to solve this problem.
this tool is great and it did all that i need, well this macro i dont need any more but i learn something in catia vba :)
i'm looking for make a allcatpart whith link, and after what i read on this post, in catia there is a function?
can some one tell me where is it please ?
