Problems installing NX75 on MAC (Library not loaded)
I try to install NX75 on a MAC. (MAC has no support in our environment)
I think that I have the correct version NX75 I do not know if the MAC OS version is OK
When starting up NX75 (QRM 7554) I got the following message report:
Process: ugraf [70791]
Path: /Applications/UGS/NX7.5_Apps/NX7.5.app/Contents/MacOS/ugraf
Identifier: com.ugs.nx
Version: ??? (???)
Code Type: X86-64 (Native)
Parent Process: launchd [317]
Date/Time: 2012-10-30 11:22:43.031 +0100
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 9803863 sec
Crashes Since Last Report: 55
Per-App Crashes Since Last Report: 1
Anonymous UUID: F74916D6-5663-43A4-9E82-09691D0F93F4
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /usr/OpenMotif-2.1.32-22i/lib/libXm.3.dylib
Referenced from: /Applications/UGS/NX7.5_Apps/NX7.5.app/Contents/MacOS/ugraf
Reason: image not found
Binary Images:
0x7fff5fc00000 - 0x7fff5fc3bdef dyld 132.1 (???) <B536F2F1-9DF1-3B6C-1C2C-9075EA219A06> /usr/lib/dyld
Model: MacBookPro5,4, BootROM MBP53.00AC.B03, 2 processors, Intel Core 2 Duo, 2.53 GHz, 4 GB, SMC 1.49f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 12 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: TOSHIBA MK3255GSXF, 232,89 GB
Serial ATA Device: MATSHITADVD-R UJ-868
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8507, 0x24400000 / 2
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0237, 0x04600000 / 4
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x04500000 / 3
USB Device: USB-PS/2 Optical Mouse, 0x046d (Logitech Inc.), 0xc040, 0x04100000 / 2
USB Device: ADATA USB Flash Drive, 0x125f (ADATA Technology Co., Ltd.), 0xc96a, 0x26200000 / 3
USB Device: Internal Memory Card Reader, 0x05ac (Apple Inc.), 0x8403, 0x26500000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8213, 0x06110000 / 3
Olaf
Version: ??? (???)
Report Version: 6
Crashed Thread: 0
Dyld Error Message:
Binary Images:
Olaf
RE: Problems installing NX75 on MAC (Library not loaded)
My apologies, after some googling:
And installing openmotif-compat-2.1.32_IST.macosx10.5.dmg, the NX startup goes further.
Now it stops because the license file can not be found.
http://www.ist-inc.com/downloads/motif_download.ht...
Mac OS X 10.4 Universal (Tiger) compat-2.1.32 openmotif-compat-2.1.32_IST.macosx10.4.dmg MD5 5601210 (5.34 MB)
Mac OS X 10.5 Universal (Leopard) compat-2.1.32 openmotif-compat-2.1.32_IST.macosx10.5.dmg MD5 8385161 (7.99 MB)
Installation Instructions
MAC OS X: Double-click on the .dmg file
The packages will be installed into the bin, lib and include sub-directories of /usr/OpenMotif-2.1.32 and linked to /usr/OpenMotif.
The location can be overridden for Linux by using the --relocate option of rpm or the --instdir= option of dpkg. If you do this then you should check that the link to /usr/OpenMotif has been made - you may have to manually set it.
Kind regards,
Olaf
