2012 October PE Exam
Hello Everybody, I just took the Oct 2012 PE exam with the HVAC/Refrigeration Depth and I thought the afternoon section was HARD!!!! I know I missed at least 13 out of 40 questions in the afternoon.
Did any of you happen to take the Oct 2012 PE Exam with the HVAC/Refrigeration Depth?
If so, how did you make out?
RE: 2012 October PE Exam
Mark your calendar for February 1, 2013 to go back to ppi.com and see if you should have gotten your results yet (people will start posting "I got my results" threads sometime late in January), the NCESS results go to all the states at the same time, but each state has the ability/obligation? to review the results for their state and they all take their own sweet time to accomplish that review. As I understand it, the passing score from NCESS is just a guideline and the states can adjust it up or down (the year I took it there were two guys going back and forth on ppi.com about a score in one state being passing and a (slightly higher) score in another state being failing, I got bored with the whole discussion before there was any resolution and they both might have been lying, a lot of that goes on at ppi.com).
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
That being said, I'm pretty sure that exam and the waiting shortened my life. That's the longest 8 hours and ten weeks that I've ever experienced.
